2015-11-11 05:43 AM
2015-11-14 09:02 AM
2015-11-14 09:29 AM
2016-03-16 03:19 PM
2017-10-11 06:45 AM
2017-10-11 07:19 AM
haymont wrote:That is because when using the Project Map as your reference, you are using all the same layer combination, pen set, scale, Model View options, Graphic Overrides, etc., as your current view.
I too am experiencing slow downs when i turn on the Trace in version 21. It could be showing just a single column and it slows down. What i have come to realise is if you are viewing drawings in the View Map as trace items it will be VEEEERY slow to the point where my computer is 10secs behind.
I have realised that if i use the Project Map views it doesn't seem to have any slow downs. This seems like a glitch as i will often use saved View Maps as trace backgrounds
2017-10-22 08:59 AM
2017-10-22 09:24 AM
KatalinBorszeki wrote:The latest version of ArchiCAD is still very very slow when using Trace Reference. And I have 64GB of RAM, 2TB superfast Solid State Drives, and a 16GB graphics card.
Hi!
We contacted Eddy and Steve but unfortunately we couldn’t reproduce the described slowness with the provided files in the mentioned ARCHICAD builds. Best, k
2017-10-22 11:29 AM
2017-10-23 07:59 AM
DGSketcher wrote:That was exactly the problem for me. I turned off the Renovation Palette and the problem was instantly gone. Works great now. Thanks.
I have seen this in all my AC21 projects as well. It doesn't seem to happen with tracing other parts of the model but it does with worksheets especially those containing DWG files placed using the Drawing Tool. A while ago (previous versions) someone flagged up that hiding the Renovation Palette cleared the problem; this still seems to be a work around in my drawings.
It would be good if GS could look at this again, it so frustrating when the beach ball turns up and disruptive of the workflow having to hide and show the Renovation Palette.
