‎2015-11-11 05:43 AM
‎2017-10-24 11:51 PM
‎2017-11-01 05:04 AM
‎2017-11-01 05:42 AM
ksweet1_nz wrote:So can you confirm that turning the Renovation Palette off did not fix your slow down when you had a Trace Reference on? Turning it off immediately takes care of the debilitating slow down I have when I have the Renovation Palette docked and a Trace Reference on.
Long time voyeur, first time poster.
I am having similar speed issues. I have two identical computers at work and home with the exact version of Windows, AC 21 and the same video drivers. The only difference between the two is that the home (sluggish version) is running 2 HD monitors. I have tried every suggestion on the forum from disabling background updates, turning on 2D acceleration, docking or closing palettes and turning off Trace. It is still slow - to the point of being nearly unworkable.
Any help or thoughts would be appreciated.
‎2017-11-01 08:27 AM
‎2017-11-01 03:33 PM
‎2017-11-01 07:33 PM
‎2017-11-04 09:04 AM
‎2017-11-05 08:59 PM
MMontgomery wrote:Its not just Drag Reference?
...I can drag the view around with the Trace Reference on without any problems. ...
‎2017-11-06 01:36 AM
Steve wrote:I should have written 'pan' instead of drag for clarity. When trace reference is on, there has been a significant performance hit when panning around the view. 'Drag Reference' hasn't been an issue.MMontgomery wrote:Its not just Drag Reference?
‎2018-06-12 04:41 AM
