TomWaltz
Using Labels in Modules
Here's a fun one:
We are experimenting with making window "assemblies" into modules, so you can place a window with all its trim and accessories as one element.
It seems to be working flawlessly in the model, but we have found that the Labels for the windows (placed as Labels, not as Dimension Markers) do not show up in the building the Modules are placed into.
We are only using the labels for the plan (and need to be able to turn on EITHER the windows or the door labels, not BOTH, or we would be using the Dimension Marker), so I would think the Module should work.
Has anyone else experienced this? Is there any known workaround?
Tom Waltz
1 Reply 1
TomWaltz
Never mind. This appears to be fixed in Archicad 9.
Tom Waltz
