V10 protection key
hi, when i try to run archicad v10 (new installation) i get 'Protection key not found or not valid (1050505) message on my pc.
when i went to uppgrade.graphisoft (with key plugged in) i got the message:'some driver have to be updated. please download the missing.... (?!). when i click the download button i get taken to the WIBU driver download page, i select windows 34 bit & it downloads but then when i try to run archicad 10 again i get the same 'Protection key not found or not valid (1050505) error message!
when i try to upgrade via safari (on my mac) i get the message: 'you can only use one instance' close this window.
this is very frustrating.
what's up?
thanks
jonathan
11 REPLIES 11
Djordje
OK.
Unplug the dongle.
Uninstall 10.
Reinstall 10.
Restart.
Plug the dongle in; XP will find it, choose Automatic configuration.
Go to the upgrade site.
Alternative:
Unistall 10.
Reinstall 9 - or only the dongle drivers if you know how.
Upgrade the dongle.
Install 10.
It should work.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
you're such a pro Djordje!
this time it worked hoora!
it did not want to install in the (v9) Graphisoft folder so i had to create a new folder for v10 first, so it probably did not install correctly the first time round...
all smiles now of course
yours in thanks
jonathan
