Ventura and Archicad 26 very slow
g r a n t
Hi....
I am NOT an IT specialist....so I may have made some mistakes when installing AC26 and Ventura. Last Fall I installed AC26 on the previous macOS. Then a week or two ago I upgraded to Ventura.
After upgrading I noticed that switching between plan and 3D views on the models there is significant lag time before the model updates. I did not have such a lag in the past.
I re-read the installation notes and Graphisoft notes to first install Ventura then install AC26. My AC26 was already on the machine. Could this lack of recommended installation sequence be a cause of delay?
Thanks,
AC26 MacBook Pro M1 Max 64Gb
Grant
I started learning ArchiCAD at age 50....bear with me,
AC26
MacBook Pro M1 Max.
Ventura 13.1
Have you installed the silicon build of Archicad 26? That will get over the recommendation of installing AC after upgrading to Ventura as it’s a completely different application and it offers significant performance improvements on the M series processors.
Lee Hankins
ArchiCAD 4.5 - Archicad 27UKI Apple Silicon 27.2.2 | Archicad 28 TP Apple Silicon
macOS Sequoia (15)
Hi, Yes. 4024 Int Full (Apple Silicone). That's why I'm finding it funny to have such a lag switching between plans and the model while the model updates. The models are fairly simple houses. Files were 25 but upgraded to 26. Thanks. Grant
AC26
MacBook Pro M1 Max.
Ventura 13.1
