‎2007-01-19 11:06 PM
‎2007-01-19 11:34 PM
‎2007-01-22 02:42 PM
‎2007-01-22 02:57 PM
‎2007-01-22 06:33 PM
EVAN wrote:Yes.
IS THERE ANY EFFICIENT WAY TO FIND THIS OBJECT BESIDES GUESS AND CHECK?
‎2007-01-22 11:04 PM
Djordje wrote:DO I JUST TYPE IN THE LINE # (BECAUSE THAT'S THE ONLY INFORMATION GIVEN)?
Yes.
WHen the error window comes, note down the object name. Use Find&Select to locate it.
COrrect the object.
‎2007-01-22 11:25 PM
EVAN wrote:Djordje was not really clear: after all the pop-ups are done (that allow you to click "OK", an Error Report window will appear (maybe in the background) that will tell you what object the error came from.Djordje wrote:DO I JUST TYPE IN THE LINE # (BECAUSE THAT'S THE ONLY INFORMATION GIVEN)?
Yes.
COrrect the object.
‎2007-01-23 03:16 PM
