‎2008-04-19 02:02 AM
‎2008-04-19 04:38 AM
‎2008-04-19 07:24 AM
‎2008-04-19 07:28 AM
‎2008-04-19 06:40 PM
‎2008-04-19 06:52 PM
DaveTex wrote:I've had a key go bad, and the symptoms were the same as you describe. Initially it was intermittent, and removing/reinserting the key would cause it to recover. But after some time it would scarcely work at all, and it was replaced.
Today I have been getting the following error messages while trying to run AC11 on my MacBookPro.
‎2008-04-21 05:01 PM
‎2008-04-21 05:08 PM
‎2008-04-21 06:18 PM
DaveTex wrote:WIBU doesn't have an auto-update feature yet, so 5.20 must be what was installed on your system, which should have been OK. If things work after the 5.21 update, then I'm guessing that something got corrupted at some point (permissions, who knows what). Or, as Ralph and Dwight suggest, your key is just in the process of failing. Keep us posted.
My question is, when I first installed AC11 did the 5.20 version got installed automatically as well or it did only after I opened the WIBU program this morning?
‎2008-04-21 07:28 PM
