Installation & update
WIN8 freeze !
archicad freezes every day on my windows 8 computer, it gets very slow or stops to be accessible. i have to kill the proces in the taskmanager.
a colleague has the same on windows 8, other colleagues with windows 7 don't have this problem
this is some frustrating problem and i don't know how to solve it. neither does our helpdesk at KUBUS
AC17, i still need to install the latest hotfix
Windows 8
4930K processor
32GB
GTX780
12 REPLIES 12
Try the latest hotfix and then report back if no change.
Versions 6.5 to 26
hotfix#6 and it still freezes
LolkeWijtsma wrote:
hotfix#6 and it still freezed once this morning
OK that wasn't it then.
When you get a freeze what does Archicad show as your available hard disc space and RAM?
Bottom right corner of screen (so long as you have the status bar turned on).
If these fgures are low then you are running out of resources.
If they are high then I am out of suggestions as I don't use Windows 8.
Versions 6.5 to 26
Zoltan Fuchs
I had the same problem some time before.
I found that win8 has a problem with the xHCI usb driver. When archicad freeze then lost its connection with WIBU key. Check WibuKey connection under Control Panel/WibuKey. I disabled xHCI in BIOS and from then it works without freezing (but I havent usb3 port now)
It was AC15 x64 /Win8 x64
fuxy
i7-4770K / 16GB / GTX560 2GB / 512GB SSD / Win10 64bit
AC21 (HUN-64 bit) / Bimx Pro / Revit 2017
thx for tips
but they don't work
- 100+GB free on harddisk
- 20+ GB free on RAM
- disabling xHCI don't work either
still on search for a solution;
- one of the files was very slow, it freezed but after waiting it was accesible again
- another file was unworkable slow
both problems were worked around by killing the process in taskmanager and reopen the files
- today i had to kill processes at least four times because of no responses
anyone?
latest hotfix didn't work either
Uninstalling Java and installing Java version 7u21 with do-not-update option doesn't work either
next tryout will be using the new chrome usbkey instead of the old blueish-green-one
no problems yet with newer usbkey
still freezing
