We are a small firm new to archicad in the last month. We are experiencing serious issues with walls displaying incorrectly, but claiming to be correct in the dialogue box. These walls obtain some kind of "phantom object" that I will outline later, and shorten in height, with an invisible object keeping them below where they should be. The issue is compounded in teamwork. I can "fix" the walls by changing them to any random number, and then changing them back to what they should be, erasing the "phantom object", but as soon as I fix mine, everyone else's walls become all screwed up, and if they fix theirs, mine immediately becomes screwed up. Only one person can view the walls as they correctly should be displayed.
As you can see, the wall is set to 0" from roof level, but it shown with four noted outlining an invisible object keeping it below that level line. This thing and those four nodes appear even when the wall is set below the level line on purpose and can happen to any wall type at any height. It happens to us with premade walls and with custom walls. With simple profiles and complex profiles.
However as soon as I correct this wall, and save changes, everyone else on the team suddenly inherits the phantom object. If they fix theirs, mine reverts to incorrect again.
Here are screenshots showing other walls and conditions:
I called archicad support and emailed them with these issues. They said they have never seen this before. I sent them the archicad file, they said they were able to replicate the problem, but have no idea how to fix it or what to do.
Any suggestions? We are not able to continue using this product in this environment.....
I also just noticed that all your walls seem to be on the generic 'ArchiCAD Layer'.
Try assigning the walls to a different layer with a different intersection group number. Perhaps they are weirdly intersecting with another wall somewhere with the same intersection number? (possibly the piece of fascia trim - try deleting it temporarily as see if there is any difference. It should be on a layer with a different int number than the wall.)
I changed the walls to correct layers, "exterior wall" or "interior wall" as necessary. The issue persists.
I do not think it is a profile issue...the problem happens with all types of walls. It happens with generic 8" foundation walls and with very complex custom wall profiles, it does not matter.
Did you set your custom roof eave profile to a different layer and then set your intersection group number to something different than your Exterior wall layer's intersection group number?
This has happened to me a few times because the custom roof eave profile is basically a wall and it tries to clean up with the exterior wall.
Robert J. Garand ArchiCAD USA 28-Build 6003 USA FULL and ArchiCAD USA 29-Build 3000 USA FULL Windows 11 Prof (64 bit) - Intel i9-14900K CPU 3.20 GHz - 64 GB RAM - NVIDIA RTX 5000 Ada Generation
I have not done much playing with layers, mostly things are just on whatever layer ArchiCAD puts them on, when you build them...
But this problem is not associated with the roof, or the eave...
This issue, as I have stated, appears on all kinds of walls. Foundation walls, wood walls, simple profiles, complex profiles, basement floor, top floor..
There is no roof or eave attached to the basement walls, yet they display this bug.
If your walls are not associated with layers and intersection numbers you could have all kinds of weird problems happening. I still think it has something to do with how these walls/profiles are cleaning up. Looking at the entire file will help per Link's request.
There also seems to be different things happening to your eaves from one screenshot to another. 77i4ee looks like there are upper end walls extending beyond the eave, where 77i4mq does not show these upper end walls beyond the eave.
