Warning; Bad BUG in Find tool
There is a bad bug in the Find tool when selecting objects
in 3D-view -> seems that the tool is zoom dependent and
excludes everything outside the current view.
(Archicad version Mac / FIN1010)
See examples;
9 Replies 9
I think it is working this way by desing.
Hello Laszlo,
It's a bad bug in my opinion…zooming should not have anything
to do with this dialog box.
There is a separate choice for "Selected area inside/outside"
why not "Zoomed area" then?
In addition the tool works differently on windows and objects.
Well, I basically agree with you, because I would like it to select all elements that are generated in the 3D Window.
I would guess this has some technological reason why this was implemented this way.
You can make a wish, if you want.
I would vote for it.
__archiben
hi lászló
it's a huge and horrible bug! editing is also affected in a similar way: if you select a range of windows in your 3D window, zoom in to get a more detailed view, and then try moving them vertically in the wall: only the windows that were in the last view get moved, not the entire selection!
i recall reporting it back in AC9 beta: i think it actually got fixed for a couple of builds, but then went right back to how it was again. i guess the fix broke something more important. whatever, it's a shocker and needs to be fixed ASAP.
unfortunately, i reported it again quite recently but seems to have been classed as 'not applicable'.
~/archiben
b e n _ f r o s t
All the bugs I have reported in the past years seem to
be redirected to "[email protected]" so better
report here in the forum
~/archiben
This is a bug, not a feature. Serious bug, being an old one makes things look more sad ArchiCAD 10 wise.
TomWaltz
~/archiben
I could live with it if there were an option in Find & Select to "Select only in current view." To make it the only option without any warning is a major problem!!
Tom Waltz
~/archiben wrote:
hi lászló
~/archiben
I agree. I would be happier if it worked differently.
