Wibu key on a Microsoft SBS 2003 server
We are running a Microsoft Small Business Server 2003. When installing wibu Key server on this I can see the key when i run the WK tool on the client, but ArchiCad do not find it when I try to start.
When I install the WK server on a XP machine in the network everything works fine.
I can set up an old XP pc to run the software in the network, but would prefer not to have extra machines in the network needing maintenance, so I wonder: Have anyone had this problem with the SBS server, and did you find any solution to the problem, i.e setting a policy on the server or anything?
Any suggestions?
0 Replies 0
