2015-10-07 01:13 PM
2015-11-03 05:34 AM
Steve wrote:Well put
I wish Graphisoft would publish a list of it's current limitations with regard to CPU's,GPU's, DirectX, Open GL versions, etc...
We all want to use the best hardware we can afford, but we do not want to buy equipment that can not be used with ArchiCAD without knowing it. I am using Maxwell Render so I have a reason for using a graphics card that would otherwise be a waste of money if I were using it only with ArchiCAD and CineRender.
If I buy modern NVIDIA GPU graphics card made for use with DirectX 12, Open GL 4.5, is it a waste of money for use with ArchiCAD 20? Will it even work with ArchiCAD?
If it were a difficult thing to know I would feel bad about asking. But I think people at Graphisoft do know. And they could provide good answers. Is it because they are embarrassed to expose the limitations of ArchiCAD? I don't know because I am relatively ignorant about computer technology.
I do know enough to recognize that there are some limitations with ArchiCAD with regard to using the latest hi-end computer processors and graphics cards. I want to know specifically what those limitations are and how long I can expect them to be a factor so that I can make an informed choice about buying new equipment. Is that too much to ask?
2016-02-03 12:56 PM
2016-02-03 06:24 PM
laszlonagy wrote:Reseller!!@#$%#@!~@#$#@!! Are you kidding me!
...Official support questions should be directed to your local reseller.
2016-02-03 06:29 PM
Vahur wrote:So you can use multiple monitors.
Now tell me at least 1 reason for spending 1300€ instead of 300 for graphic card.
2016-02-04 12:58 PM
Steve wrote:I use multiple monitors without any lag with a $150 graphic card.
2016-02-05 07:41 AM
Steve wrote:Yes, and see the picture on the screen!Vahur wrote:So you can use multiple monitors.
2016-02-05 07:46 PM
laszlonagy wrote:But what would be feasible is for every ArchiCAD user to run a test and post their results. What GS needs to provide is the test model and a little program that would report the specific settings, drivers, etc... of the test.
It is practically impossible to test all the various gaming cards from the multitude of gaming card manufacturers with all their special tweaks and overclocking and various drivers that are different from the reference drivers provided by NVidia or AMD...
2016-02-09 09:04 AM
Steve wrote:Tere is no point testing all the cards at all unless ArchiCAD engine is using all the hardware possibility properly.
There is no point in testing certain graphics cards that we know ArchiCAD can not possibly benefit from.
2016-02-09 06:35 PM
Vahur wrote:Exactly! These are the kind of limiting factors we need to know about so we can make an informed choice about what hardware to invest in for using ArchiCAD.Steve wrote:Tere is no point testing all the cards at all unless ArchiCAD engine is using all the hardware possibility properly.
Why AutoCAD has no problems handling 500 000 lines in the screen, but ArchiCAD freezes with already 10 000 units?
Clearly it is the software issue!
2016-02-12 12:47 PM
