as you see in the picture when i try to edit the slab some trace problems occurs. when i first try to move Mouse there is no problem but when i move the Mouse for a second time, the trace of the first Mouse move stays on the screen. Until i zoom out or zoom in trace stil stays on the screen. This very irritating. I removed and reinstalled archicad over and over but problem stil goes on. Pls help
And also there is one more problem. When i select something normally it is highlighted with a green hatch and black dots on the corners. But when i zoom in or zoom out, those dots and green hatch disappears and there is only green lines remain as you can see in the Picture. İ never experienced these problems in archicad 12. I cant use archicad 13 like this so really i need your help over here.
and a new problem over here. As you can see in the Picture again.when i use marquee tool. Its trace remains in the screen over and over. And not even one square. At least 4 differents square traces remains on the screen. I get more problems with every minute i use archicad 13. I am really getting crazy
This is definitely a graphic card problem. First of all update the driver of your videocard (or an older one).
If it is not solved, read this wiki about video cards: http://www.archicadwiki.com/Video Cards for ArchiCAD 13
If you cannot solve it, you can always turn off hardware acceleration or buy a different video card.
If you mean the info about free hard drive space and memory usage: it is gone in AC13. I don't know why but it was taken out of the program as far as I can see.
Loving Archicad since 1995 - Find Archicad Tips at x.com/laszlonagy AMD Ryzen9 5900X CPU, 64 GB RAM 3600 MHz, Nvidia GTX 1060 6GB, 500 GB NVMe SSD 2x28" (2560x1440), Windows 10 PRO ENG, Ac20-Ac28
