Got a minute? We appreciate your feedback:
Graphisoft Learn survey
Forum Posts
TIP: broken files - other solution
(It was to be published in "Working i Archicad" section- but it did not let me - forwarded me to index) It hapened - I could not open files from last two days... Bug reporter showed up on processing "variables" I tried TIP's but they are not complete...
Roofmaker Problems
I had to modify the property script of "Rafter2_1" and "Collar Beam2_1" that Roofmaker uses to place rafters and collar ties. After modifying the two objects roofmaker will not place them. I have attached a picture showing the error I am receiving. A...
Red Enthusiast
  • 3576 Views
  • 0 replies
  • 0 likes
our of memory and Can not print problems
On of our .pln files for ARchicad 8.1 (Mac Os X) is locking up archicad. WhenI try to just open it on a MAc with just 512 MB of memry it wont open due to a memory error. This problem is replicated on multiple machines. But it only apparent in this pa...
  • 4026 Views
  • 2 replies
  • 0 likes
G5 Server Questions!!
We are contemplating buying a new G5 1.25ghz Server to replace our existing G4 400mhz Server, that is not even running server software and only has a 20 gig hard drive. My first question is because the server will come with OS 10.3 and all computers ...
  • 5870 Views
  • 4 replies
  • 0 likes
lock file not found from Draft copy
I somehow got locked out of the teamwork file after taking a draft copy home and working on it. When opening the draft and signing in I get a message that a lock file has been corrupted and should be trashed. the lock file does not exist. It can't be...
  • 6217 Views
  • 4 replies
  • 0 likes
can't print out of 8.1 w/ MAC G5 & 10.3.1
I'm running a MAC OSX 10.3.1 on a dual 2 ghz G5. I can't print out of 8.1, it crashes immediately upon selecting the print dialogue box. I have reinstalled 8.1 to no avail. I sent the file to my G4 running OSX 10.3.1, but it also would not print. I d...
  • 5873 Views
  • 4 replies
  • 0 likes
IP address for plotter
Hi all: Does anyone know how to assign a MAC address to a plotter on the network, that does not have an IP address. I understand that the IP address is assigned by the print server box- in most cases jet direct- but we are using a castelle print serv...
  • 3686 Views
  • 0 replies
  • 0 likes
Message: Cannot save Plan file!
Since we upgraded to V8 we ocasionaly sometimes very frequently get a message 'Cannot save Plan file!' when we save normally , or even just after saving without having made any changes at all. Than saving again and it works. Sometimes it takes two or...
  • 4876 Views
  • 2 replies
  • 0 likes
