Installation & update
cant select hotlink modules
im building a project using hotlink modules. I have placed hotlink modules in the plan view but when I select them they display selected for about a second and then deselect themselves. If I switch group off then I can select the individual parts but once I switch groups back on, the whole deselects itself.
If I go to the 3d window, I can select them fine and move/rotate etc. but I really need to move them around in the 2d window.
I have 3 hotlinks. 2 are buildings that are having this problem. The third is a simpler file which is the site which consists of a couple meshes and a few polylines and this one is fine. They are all .pln.
1 REPLY 1
problem solved; kind off. heard from cad-image that removing their electrical add on which is being used in the hotlinks that don't work (not in the hotlink that does work) solves the problem. they have reported this problem to their developer.
