2004-08-04 07:43 AM
2004-08-04 10:43 AM
schagemann wrote:mm. good stuff, eh? and not a 'restore' tool in sight to make use of them.
so i went around and had a look at a few other macs in the office and found the following: on average the cache files take up around 2 GB - one computer even had 11 GB worth of archicad caches. to me this looks as if archicad does not delete the cache files on exit...
however, i wonder what the reason for this might be?
has anyone else had that problem before?
was this bug, if it is one, resolved in any of the recent versions?
daniel.
2004-08-04 11:04 AM
2004-08-19 02:28 PM
2004-11-23 06:34 PM
2004-11-23 09:23 PM
another Moderator
2006-09-12 11:13 PM
2006-09-13 12:17 AM
SteveC0013 wrote:when archicad crashes it doesn't get to clean things up in the way it would if it was able to run through its usual 'quit' process. maybe it should check for 'out-of-date' caches on startup too?
Is there anything I can do to stop accumulating them?
2006-09-13 04:43 AM
