Installation & update
green lines in 3d modelling
Hello, anyone know how to get rid of these green outlines in 3d? as you can see they don't match the volume so they are excruciatingly annoying...
(archicad 23 -Mac)
4 REPLIES 4
It looks like you have accidentally created extra edges on your Morphs.
You will have to select them and delete them one by one.
Before doing that, check if the Morph geometry is not corrupted.
Morphs must be carefully created to avoid this kind of issues.
HTH.
Is your model a long way from the project origin?
There is another post here somewhere an I am pretty sure that was the problem.
Either that of make sure your video card drivers are up to date.
If I can find the post I will add a link.
It actually is very far but I cant find how to reset the project origin.. Do you have an idea on how to do it?
Best Regards,
You can not "reset the Project Origin" since it is the one true point of reference in the project file that never changes and can never be changed.
What you can do is move your whole model closer to the Project Origin.
