2024-07-13 02:29 PM
@Graphisoft:
Are there any experiences and test results about Archicad (27 + 28) is performing on macOS 15 Sequoia? (currently beta status)?
Thanks.
Regards
Roman
Operating system used: Mac Apple Silicon 15 Sequoia
Solved! Go to Solution.
2024-07-24 02:18 PM
Hi there,
At the moment, we're not aware of any critical issues in Archicad on macOS 15. However, please note that we're still in the process of testing both Archicad and BIMcloud, and there will be more OS updates until the official release, so this may change in the future.
You can find an article with the latest news about the compatibility and known issues on macOS 15 here.
Kind regards,
Oleksandra
Oleksandra Vakariuk
Technical Support Engineer2024-07-13 08:41 PM - edited 2024-07-13 08:41 PM
I’d be interested in knowing this too. I used to run the Betas of both Archicad and macOS to test but Apple changed the virtualisation so I couldn’t install a VM. Apparently this all changes after Sequoia so I’ll be able to test the next versions.
2024-07-14 09:00 PM
How will it change?
2024-07-14 09:43 PM - edited 2024-07-14 09:45 PM
Apple have updated their virtualisation SDK so after Sequoia you will be able to run any future macOS system within Parallels. At the moment it has to be the same os as the macOS on which Parallels is installed. You will be able to run the next major release after Sequoia within Parallels whilst still running Sequoia as your main OS.
2024-07-15 09:27 PM
That is Great! or I mean That is Brilliant ...
2024-07-24 02:18 PM
Hi there,
Kind regards,
Oleksandra
Oleksandra Vakariuk
Technical Support Engineer2024-09-18 04:50 PM
Good morning everyone, following the update to macOS 15, every time I try to use Cinerender I get an error message.
I have the latest version of Archicad 27.
Am I the only one??
2024-09-19 12:46 AM
What is the exact error message you are receiving?
a month ago - last edited a month ago by Laszlo Nagy
a month ago
Hi @Luca Ancorati,
I use macOS 15 and don't experience this issue with Cineware. Please check this article for a possible solution.
Oleksandra Vakariuk
