2005-10-23
04:10 PM
2025-01-29
03:51 PM
Molinda Prey
2005-10-23 05:58 PM
2005-10-23 10:07 PM
Achille wrote:Note, Tonci, that unless you created a perfect circle, the hole created will likely be polygonized. You can control how tightly the magic wand traces by going to Tools > Magic Wand Settings If you are not happy with the hole, just do an "Undo", change the magic wand settings to something more appropriate, and try again.
welkome to Architalk... to make the hole its really easy...
1)draw a circle [or free-form shape] of the hole you want to make [using 2D tools at the proper location on the slab - and perhaps in a hidden line layer if you don't want to delete the linework after making the hole]
2) select the slab [and activate the slab tool if it is not active]
3) press the space bar. the cursor will turn into the magic wand
4) go on the circle [move the mouse to either an edge of the linework or inside the linework. If on the edge, the magic wand will turn black and the 'halo'/'sparkles' will change shape. If inside the space, you will not see a change in the icon]
5) click... done
2005-10-24 05:49 AM
2005-10-24 11:18 AM
2005-10-24 01:23 PM
