2016-05-04 08:58 AM
2016-05-09 09:14 PM
it is not easy to predict what will AC20 demand. But current picture tells me: "go for cores, not frequency".I thought that if the CPU are from the same generation (14nm) the CPU underneath are equal speed.
2016-05-09 09:57 PM
tjibbe wrote:This is not corect math 4x3.6 not equal to 6x2.4 in computer world.it is not easy to predict what will AC20 demand. But current picture tells me: "go for cores, not frequency".I thought that if the CPU are from the same generation (14nm) the CPU underneath are equal speed.
4 core @ 3.6ghz (4x3,6=14,4ghz)
6 core @ 2.4ghz. (6x2,4=14,4ghz)
But for AC the 6-core will be faster? If so, is this because other processes don't need the full 3.6ghz. But only need a little part and the rest of the ghz can not be shared with AC?
2016-05-09 11:46 PM
2016-05-11 12:58 PM
shtarkel wrote:100% CPU load i see only during the photorendering. While working with plan/section/elevations/3D window CPU utilization is ~ 20%
When ARCHICAD renders it uses all the cores at 100%! Also the cores are used intense in section/elevation.
So more cores and overclocked is the best solution, that's why I use the Intel 3930k.
2016-05-11 02:11 PM
2016-05-11 03:06 PM
shtarkel wrote:I think that section, which is taking more than a minute to regenerate, is complex enough. There are 15 sections, 4 elevations
Thats exactly what I said! Try making a complex section and see your CPU? Make a screenshhot again
2016-05-11 04:25 PM
2016-05-12 08:28 PM
shtarkel wrote:20% is not enough for me. It is quite annoying to wait 5-10 minutes just to change some property for all stud walls in the plan.
20% is because the engine behind ARCHICAD don't utilize all the CPU power but 20% is not small, also when I update drawings, make complex sections...etc. The CPU utilization has spikes!
2016-06-04 10:22 PM
2016-06-10 09:18 PM
Jacques wrote:I did it as well. Every core is utilised 0-20%
I know it's one month later, but rather than looking at the graph showing the 'average' CPU usage, open the Resource Meter and look at the graph for each CPU core / virtual core. You should be able to see how the cores are used (or not) when updating sections / elevations / shadows etc. as you can see all the cores in one view.
