plotmaker 9 - using publisher
I am currently using Archicad 9; When in plotmaker I go to publisher to create a dwg file. In the past I have been able to create a dwg file successfully, however now the format dialouge box is missing the option to create a dwg file.
Does anyone have any answers or suggestions?
Thanks!
6 Replies 6
Could you post a screen shot?
how can I post a screen shot?
If you use a PC press Prt Scr ((upper right on your keyboard) Print Screen), then open Photoshop (or Outlook, Word etc etc) and make New file. Now press Ctrl+V (Paste) and then screenshot will appear. Save as Jpg and then upload on the forum.
On a Mac press the apple key, shift and 3 at the same time and the image will be on your desktop. Load this into the forum. (this is why i would never get a MAC, too bloody complicated)
Here is the screen shot
TomWaltz
You may need to check your installation. It should be there.
Look in ..../Graphisoft/Archicad 9/Add-ons/Import-Export. There should be a file called DXF-DWG In-Out.
Tom Waltz
I deleted my add-ons folder and pasted a new one. Everything works now.
Thanks for your help
