ā2021-07-12
10:14 PM
ā2023-05-24
10:18 AM
Rubia Torres
ā2021-07-26 05:29 PM
ā2021-07-27 11:11 AM
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
ā2021-07-28 07:30 PM
ā2021-07-30 02:27 PM
RandyC wrote:Hi Randy,
not sure how to make a pln small enough to send.
However the attached shows the line colors of the carcass / cabinets and contour lines
does this help ?
Minh Nguyen
GRAPHISOFT
ā2021-07-30 02:33 PM
Electric wrote:Hello,
Hello Minh,
Could you please also send this request to the developers.
Thanks,
Minh Nguyen
GRAPHISOFT
ā2021-11-16 12:18 AM
Hi Minh,
Rather than putting the carcase and cabinet line parameters back in the object, would it be possilble (easier even) to add those to cabinet parameters in the MVO configuration? That way we could hide the lines in some views and show them in others based on MVO.
cheers,
-Bryan
ā2021-11-23 06:59 PM - edited ā2021-11-23 06:59 PM
Adding to the issues.
There is no ability to control edge visibility in 2D plan for units that don't have a counter. So you cant display three adjoining wall units as a rectangle which you quite often want to do at low LoD.
ā2021-12-10 06:37 AM
Can I please confirm, as per the original post, is there a way of showing the cabinet carcass/ shelves and door swings in elevation? This is separate from the discussion of the level of detail and lines shown in plan. MVO have has been set to full, however the carcass or door swings still don't seem to be showing in elevation.
ā2022-01-10 04:27 PM
Hi, is it something new in this Topic ? Can I design invisible line ?
I'd like to get rid of lines this 2 lines under a Keep sink to be visible.
MVO - It's not helping in this case because how was said this hiding sink.
ā2022-01-11 11:22 PM
I'm going to echo this request. The lines that define the edge of the sink should really disappear (especially in the undermount sink). The sink in 2D doesn't look undermounted with them there and my boss is not happy about that. For now I'm having to use a white fill to cover them. I also tried using the Cabinet with Sink object as it's 2D sink looks correct. The problem is, however, that I can't get rid of the top of the base cabinet. If I turn off the counter, it's a solid top to the base which then conflicts with my sink. Not great.
