AC25 Cabinet Objects
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2021-07-12
10:14 PM
2023-05-24
10:18 AM
Rubia Torres
1) show dashed lines indicated door swings and shelving behind the doors in 2d elevations
2) at a two segment base cabinet, when I set the lower segment to a double hung door with drawers above I can't figure how to show two drawers side by side above the door panels. It only appears we can have one large drawer.
MacBook Pro M1 Max, 64GB
macOS Sequioa
- Labels:
Default Archicad Libraries
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2022-07-28 04:48 PM - edited 2022-07-28 04:55 PM
Dashed lines for shelves behind cabinet door? I am testing AC26 now, but it seems like this function is still missing. This is basically the only reason we are still stuck with pricey 3rd party solutions.
I can set the door to be glass and transparent, then the shelves will show as solid lines, not dashed. (extra issue: I am seeing the side walls also, which I'd like to not see) Probably add some graphic override magic, but last I checked, GO applies rules to the full object not to certain parts of it, so I guess I will have a result with all the lines dashed, even the ones I want to be solid.
It's sad, because they have put a lot of work in this new cabinet tool, but this simple function keeps me from using it.
first ArchiCAD: 6.5
- « Previous
- Next »
- « Previous
- Next »
