Ward__Anna
AC27 Door default setting stuck
I am having an issue with the door setting - the default is stuck to door 27 and will not provide me with any other options for my floor plan.  I have attached a screen-grab of what I see when I select doors as opposed to what appears when I select windows (objects also works fine).
I have tried various things in the Library Manager to no success - archicad27 is installed in the library manager under libraries in project, I've tried restarting my computer and upgrading my mac system to the latest version,  no success.  If I go in under 'elements' I can see archicad library and the other door options there, but I can not insert them into my project.
Has anyone struck this before?  My project files work fine on my tutor's computer - he has access to all door options.  When I start a new project, I have the same issue.
Any help would be appreciated.  Thanks.
Operating system used: Mac Apple Silicon Sonoma 14.5
1 Reply 1
There is a tiny little arrow that will expand the dialogue.
