2023-07-05 10:17 AM - edited 2023-07-05 10:19 AM
Hello
I like to generate the Id names automatic. The names should depend on the storey they are.
For example die windows in the first storey should named like: 100, 101, 102, 103.... and on the second storey they should named 200, 201, 203....
Is there a possibility to access the storey where the paticalar window is in?
Thank you in advance.
TimSim
Solved! Go to Solution.
2023-07-05 10:27 AM
You can use the Element ID manager to do exactly this.
2023-07-05 10:27 AM
2023-07-05 02:54 PM
Tank you very much!
