Access Storey properties with Python
TimSim
Hello
I like to generate the Id names automatic. The names should depend on the storey they are.
For example die windows in the first storey should named like: 100, 101, 102, 103.... and on the second storey they should named 200, 201, 203....
Is there a possibility to access the storey where the paticalar window is in?
Thank you in advance.
TimSim
Erwin Edel
You can use the Element ID manager to do exactly this.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
Erwin Edel
www.leloup.nl
TimSim
Tank you very much!
