TimSim
Access Storey properties with Python
Hello
I like to generate the Id names automatic. The names should depend on the storey they are.
For example die windows in the first storey should named like: 100, 101, 102, 103.... and on the second storey they should named 200, 201, 203....
Is there a possibility to access the storey where the paticalar window is in?
Thank you in advance.
TimSim
1 Solution
Erwin Edel
You can use the Element ID manager to do exactly this.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
Go to post
Erwin Edel
www.leloup.nl
TimSim
Tank you very much!
