Ambiguous Origins
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2010-08-09 05:13 PM
‎2010-08-09
05:13 PM
Thanks,
7 REPLIES 7
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2010-08-09 05:30 PM
‎2010-08-09
05:30 PM
What do you mean by "ambiguous origins"?
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
15" Retina MacBook Pro 2.6
27" iMac Retina 5K
AC 19 6006 & AC 20
Mac OS 10.11.5
27" iMac Retina 5K
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2010-08-09 05:33 PM
‎2010-08-09
05:33 PM
See attached.
It shows up on the library manager...
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2010-08-09 05:43 PM
‎2010-08-09
05:43 PM
I have never seen this before, but I am still on 12 so this may be a feature of the newer embedded library system.
At a glance the objects in question appear to be from AC 12. I would guess that has something to do with this. Perhaps someone working on AC 14 can confirm this. What does your library manager look like?
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
27" iMac Retina 5K
AC 19 6006 & AC 20
Mac OS 10.11.5
27" iMac Retina 5K
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2010-08-09 11:53 PM
‎2010-08-09
11:53 PM
From AC14 help:
Objects of Ambiguous Origin
An object in this category has been placed in the project, but duplicates of this object (that is, objects with the same ID as the placed object, though they may be named differently) exist in at least two linked libraries. ArchiCAD randomly uses one or the other source for the object’s placed instances.
To avoid this situation, you should replace the placed instances with one of the duplicate objects from the loaded libraries.
(To do this, you can use Find & Select to locate the placed instances of the ambiguous object. Then choose a library object from the loaded libraries to replace the ambiguous object.)
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Mac OSX 10.11.1
AC5-18
Onuma System
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2010-08-10 05:01 PM
‎2010-08-10
05:01 PM
Aaaand what is not said in the help: get rid of the duplicates in the loaded libraries in the first place. You won't have any ambiguous situations after that!
Regs,
Regs,
Zsolt Táskai
ArchiCAD Development - GDL Team
AC13, AC14 and upwards...
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2010-08-10 05:13 PM
‎2010-08-10
05:13 PM
ztaskai wrote:Thanks Zsolt, I hope they add your tip to the AC Help.
Regs,
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
Mac OSX 10.11.1
AC5-18
Onuma System
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2010-10-06 06:40 PM
‎2010-10-06
06:40 PM
Curious if there is a way to find out which objects are "placeable duplicated objects" within a loaded library. There is no detail in the information dbx about which objects are duplicates
