2024-02-07 07:30 PM
Any way to angle one side of a window jamb to follow the roof line?
2024-02-07 09:16 PM
HI @architect
There are some Special Windows available in Archicad Library but no one has that angled side as you need. Anyway, you could check this oldy article to create a custom window/door with any form you want:
https://community.graphisoft.com/t5/Modeling/How-to-create-Custom-Window/ta-p/303432
Regards.-
2024-02-07 10:04 PM
@architect Why don't you do a curtain wall piece? That has a high level of customization as opposed to a non-parametric custom object...
Sorry to somewhat contradict you @Ricardo Lopez . I just wanted to offer another solution.
Unless really versed in GDL, it is hard to master changing any parameters of a custom object (materials, surfaces, contours...). That is a limitation I will probably always have personally...
2024-02-08 05:07 AM
Do note, a Curtain Wall will be seperate from your wall and you will still need to cut out a hole in your wall.
| Win11 | i9 10850K | 64GB | RX6600 | Win11 | 5900X | 32GB | GTX2080TI |
2024-02-08 08:44 PM
I haven't check it in a while, but there use to be an add-on named ArchiGlazing that could help too.
I don't know if it is still available. 🤔
