architect
Angled Jamb Window?
Any way to angle one side of a window jamb to follow the roof line?
4 Replies 4
Ricardo Lopez
HI @architect
There are some Special Windows available in Archicad Library but no one has that angled side as you need. Anyway, you could check this oldy article to create a custom window/door with any form you want:
https://community.graphisoft.com/t5/Modeling/How-to-create-Custom-Window/ta-p/303432
Regards.-
Ricardo López, M. Arch.
Lucian Laculeanu
@architect Why don't you do a curtain wall piece? That has a high level of customization as opposed to a non-parametric custom object...
Sorry to somewhat contradict you @Ricardo Lopez . I just wanted to offer another solution.
Unless really versed in GDL, it is hard to master changing any parameters of a custom object (materials, surfaces, contours...). That is a limitation I will probably always have personally...
AC 7-26 (current 27)
iMac 3.6 Ghz 10Core Intel Core i9 / 12b GB / AMD Radeon Pro 5700 XT 16 GB / Ventura 13.4
https://globularcreative.wixsite.com/home
Lingwisyer
Guru
Do note, a Curtain Wall will be seperate from your wall and you will still need to cut out a hole in your wall.
Ricardo Lopez
I haven't check it in a while, but there use to be an add-on named ArchiGlazing that could help too.
I don't know if it is still available. 🤔
