Another math challenge
Rob
I just do not know how to tackle this problem and/or if it is solvable with given variables. Basically I would like to calculate the coordinates of the tangential fillet center of two segments.
if someone could help I would appreciate
ta
X1,Y1,X2,Y2,X3,Y3 - known
Xa,Ya,Xb,Yb - known
Xc,Yc - ???
::rk
8 REPLIES 8
Frank Beister
You should be able to calculate it by pythagoras and TAN. I have added some length (L,r), which are known out of your settings
Rob
I appologise, I have forgotten to mention that alpha is not known, it's there just to demonstrate the centerline of the angle.
::rk
Frank Beister
Are you shure that the both distances L are identical? Elsewhere the center line and alpha is not the only problem. 😉
Rob
yep, the L distances are identical
::rk
I think if you know the coordinates of all three corners of the triangle, you should be able to find out any of the angles of the triangle. Alpha will be half of the angle at point 2.
Rob
thanks laszlo for your suggeston, it did not solve the problem, however it gave me the starting idea and finally solution after couple hours of sketching and calculating.
::rk
LiHigh
You can also avoid Alpha:
! (X0, Y0) is the center of the arc
! D = distance betwen center and point (X2,Y2)
R^2 = (Xa-X0)^2 + (Ya-Y0)^2
R^2 = (Xb-X0)^2 + (Yb-Y0)^2
L^2 = (Xa-X2)^2 + (Ya-Y2)^2
L^2 = (Xb-X2)^2 + (Yb-Y2)^2
D^2 = R^2 + L^2
5 unkowns & 5 Equations, solvable.......
Howard Phua
Win 10, Archicad 19 INT
I know the post I'm adding to is old, but it's related.
I was working on a much simplified detail symbol which shows the clip polygon with filleted corners. I managed to figure out how to draw the clip polygon, . Simple enough, you just put the clip coordinates into memory and draw a polygon but I could not figure out how to add the nodes to create filleted coners.
I attached the library part, but following is the"for next" loop that extracts the clip polygon.
add2 AC_RefCoord[1][1], AC_RefCoord[1][2]
for i=1 to AC_ClippNodes
if i<>AC_ClippNodes then
put AC_ClippCoord[1],AC_ClippCoord[2],1
next i
poly2_ AC_ClippNodes, 1,
get(nsp)
