ā2007-02-23 02:44 AM
ā2007-02-23 10:44 AM
ā2007-02-23 11:03 AM
ā2007-02-23 11:36 AM
ā2007-02-23 11:41 AM
ā2007-02-24 02:34 PM
ā2007-02-25 10:34 AM
I think if you know the coordinates of all three corners of the triangle, you should be able to find out any of the angles of the triangle. Alpha will be half of the angle at point 2.thanks laszlo for your suggeston, it did not solve the problem, however it gave me the starting idea and finally solution after couple hours of sketching and calculating.
ā2007-02-26 11:33 AM
ā2010-01-20 07:48 PM
