Any straightforward way to morph a curved duct
Hello, I need to draw a curved shape duct-like object.
But in Morph tool, there is no a straignt forward way because the morph refuse to choose to enclosed polygon.....I have to (1)morphor one polygon, then (2) draw again the path, copy and offset the first polygon, then extrude it, the intersect it.....
Or other tools can make it in a straight forward way
Lingwisyer
Guru
Have you tried using a complex profile with the rail tool?
Ling.
AC22-28 AUS 3001Help Those Help You - Add a Signature
see attachment
Lingwisyer
Guru
Ling.
Hello, Lingwisyer
Is it railing tool for stair?
As my trying before, the railing tool sometimes not match the steps when the stairs turn around at corners.... I try this way later
OK Thanks
