Service alert: BIMcloud SaaS disruption in the US Read more
ArchiCAD 16 to 17 Object 3D Vectorial Hatching?
We recently have had to upgrade a project to ArchiCAD 17 for BIMx reasons.
Most the translation went fine (spot levels went crazy though)
Our problem I cant solve is in the elevations as the 3D vectorial hatching which is derived from our objects are not appearing.
Basically we have objects which colour appears fine in 3D, however their 3D vectorial hatching has dropped off.
I initially assumed this is a problem with the new building materials feature, however walls which share the same material settings appear fine in elevation
I'm confused (....again)
1 REPLY 1
Check for renovation filters - it might be a problem with fills.
Best Regards,
Piotr
