Hello
I am having troubles with the object tool in Archicad 13, and I cannot find the answer in help.
I am building a library by making collections of lines and hotspots, and saving a selection as a library object .gsm, in the embedded library.
I have then placed these .gsms into plans and interior elevations (2D, drawn up under "Details").
Now, for example, I realised that I needed another two hotspots in an object, so I edited my original set of lines/hotspots, and resaved the selection with the same name, replacing the old file.
Now when I go back to my detail, it doesn't update. The new hotspots are not there. Even if I close/open the file, try deleting the object/object file, and regenerating, and then replace in the detail file, the new hotspots still don't come up. If I open the .gsm file 2D full view, they are there. But not in the layout in which I have placed the object.
I would have expected that there would be a way to update all objects, so that for example if I decided to change a width of a part of a door, add hotspots etc., then I can just do so once in the object file, and then click update and all the instances in the main file receive the changes. How does one do this?
Thanks in advance for your help.
