Archicad 28 No Library
Brad Norris
Just downloaded 28.  Migrated and open a project from 26.  The entire model is without library parts and surfaces. I went to library manager and the 28 libraries are "missing". What did I do wrong? Seems there is no library 28?  The entire model is the dreaded purple and black checkerboard. and library parts are the big black blobs.
Operating system used: Windows 11 pro
13 REPLIES 13
Anyone out there that uses BIMcloud with this problem?  I eliminated all libraries except 26 which is where the windows are.  and still have the big black blob.  Also if I'm understanding I can't use the 28 libraries, i can't even have it in the project?
Guru
"which is where the windows are"
Have you expanded the missing library part list to see what it is looking for?
I think you need to load in the Archicad library 28 and MEP Library 28 then lets see how it goes.
In the end what is your Objective?
ArchiCAD 9 onwards
You may need to load the relevant migration libraries too.
Lee Hankins
macOS Sequoia (15.1.1)
Setup info provided by author
