Brad Norris
Archicad 28 No Library
Just downloaded 28.  Migrated and open a project from 26.  The entire model is without library parts and surfaces. I went to library manager and the 28 libraries are "missing". What did I do wrong? Seems there is no library 28?  The entire model is the dreaded purple and black checkerboard. and library parts are the big black blobs.
Operating system used: Windows 11 pro
Setup info provided by author
13 Replies 13
Brad Norris
Anyone out there that uses BIMcloud with this problem?  I eliminated all libraries except 26 which is where the windows are.  and still have the big black blob.  Also if I'm understanding I can't use the 28 libraries, i can't even have it in the project?
Guru
"which is where the windows are"
Have you expanded the missing library part list to see what it is looking for?
ryejuan
I think you need to load in the Archicad library 28 and MEP Library 28 then lets see how it goes.
WINDOWS 11 PRO
Lee Hankins
You may need to load the relevant migration libraries too.
Lee Hankins
ArchiCAD 4.5 - Archicad 29
macOS Tahoe (26.0)
