‎2007-02-21 07:38 PM
‎2007-02-21 08:32 PM
‎2007-02-21 10:05 PM
Richard wrote:No, Favorites can only help quickly chose for certain library part,
The way to have them easily available is to use "favorites".
‎2007-02-22 02:54 AM
SPINCODE wrote:Have you actually tried saving this dimension style as a favorite? It works on MY system very well. Once the dimension favorite is created, you can select incorrect dimensions and double-click on the favorite and they will all change.
but it does not give full functionality of dimension line.
For example an ability to quickly correct origin of level dimensions chain, using User Origing.
‎2007-02-22 07:02 AM
‎2007-02-22 07:52 AM
Richard wrote:Look at pictures. I want to modify dimension line style. I want to change arrow markers on the Native dimension Line. (Not to use library parts!)
‎2007-02-22 10:02 AM
‎2007-02-23 05:02 PM
laszlonagy wrote:I think, it is not good!
If I understand correctly, you want to create new styles of the Elevation Dimension besides the ones available as default.
This is not possible for Dimensions because the Dimension Marker is not a GDL Object but is hard-coded in ArchiCAD.
‎2007-02-24 04:35 PM
SPINCODE wrote:I would really press your country distributor to address the problem with Graphisoft.laszlonagy wrote:I think, it is not good!
Only hope is to duplicate this subject in Wishes.
‎2010-09-13 01:08 PM
