Albertchliu
Archicad help - Cannot download the motorbike in "Object"
My teacher shown me that there are a lot of motorbike can be download (as shown in clouded figure below).
However, in my PC, doesn't show those motorbike.
Is my download setting went wrong ?
Is it possible to advise how I can modify my setting in order  to show those download-able motorbike ?
12 Replies 12
Eduardo Rolon
In the "Gear" Icon check "Search BIM Components Portal" and they'll show up.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
When you select that object, on the right hand side you should see a 'Download' button
Albertchliu
Dear Barry and Edurado,
Thank you for your reply!
However, I still have not found the icon.
I was wondering if my library missing anything ?
Once you have types something in the search bar, go to settings and make sure it is searching the BIM Components Portal.
Lingwisyer
Guru
If need be, you could always download the objects straight from the BIMComponents website.
Win11 | i9 10850K | 64GB | RX6600 Win11 | i9 11900K | 32GB | GTX2080TI
Albertchliu
Dear Barry
Thank you so much indeed!
I have turned the button.  However, I still haven't find the object I need.
thank you once again!
Albertchliu
Dea Lingwisyer,
Is it possible to provide address for the BIMComponent website ?
thank you!
JeffH
https://bimcomponents.com
AC24 / AC26 / AC27
Win10
Can you access the BIM Components web site directly?
https://bimcomponents.com/
You will need to sign in with your Graphisoft ID.
Maybe your Archicad is not signed in?
Help menu > Sign in.
