2024-10-21 04:26 PM - last edited on 2024-10-21 07:23 PM by Karl Ottenstein
My teacher shown me that there are a lot of motorbike can be download (as shown in clouded figure below).
However, in my PC, doesn't show those motorbike.
Is my download setting went wrong ?
Is it possible to advise how I can modify my setting in order to show those download-able motorbike ?
2024-10-21 05:49 PM
In the "Gear" Icon check "Search BIM Components Portal" and they'll show up.
another Moderator
2024-10-22 02:40 AM
When you select that object, on the right hand side you should see a 'Download' button
2024-10-22 11:58 PM
Dear Barry and Edurado,
Thank you for your reply!
However, I still have not found the icon.
I was wondering if my library missing anything ?
2024-10-23 02:58 AM
Once you have types something in the search bar, go to settings and make sure it is searching the BIM Components Portal.
2024-10-23 05:47 AM
If need be, you could always download the objects straight from the BIMComponents website.
AC22-23 AUS 7000 | Help Those Help You - Add a Signature |
Win11 | i9 10850K | 64GB | RX6600 | Win10 | R5 2600 | 16GB | GTX1660 |
2024-10-23 02:12 PM
Dear Barry
Thank you so much indeed!
I have turned the button. However, I still haven't find the object I need.
thank you once again!
2024-10-23 02:13 PM
Dea Lingwisyer,
Is it possible to provide address for the BIMComponent website ?
thank you!
2024-10-23 02:32 PM
2024-10-24 03:50 AM
Can you access the BIM Components web site directly?
You will need to sign in with your Graphisoft ID.
Maybe your Archicad is not signed in?
Help menu > Sign in.
