Cosminn
Array Parameter
Hi everyone,
Please see attached.
Any help = will be appreciated.
Thank you.
Daniel
Sincerely,
Daniel
3 Replies 3
Bruce
Without knowing what it is you're trying to achieve, it is impossible to give proper help. However, what you've already created should do the trick: just refer to your array parameter in your script.
Bruce Walker
Barking Dog BIM YouTube
Mindmeister Mindmap
-- since v8.1 --
AC27 5060 INT Full | Windows 11 64 Pro | 12th Gen Intel i7-12700H 2.30 GHz | 64 Gb RAM | NVIDIA GeForce RTX 3060 32 Gb
You can expand the array size for example in the master script, but
it would be useful to know what is the purpose for this.
for yy=1 to pey
	parameters pexy[yy][1]= yy!--rows
next yy
for xx=1 to pex
	parameters pexy[1][xx]= xx!--columns
next xx
Cosminn
Thank you so much for all your Help .
Here is the purpose of having that array parameter - and I think I did It. I need the user to have the possibility to change the Glass Panels based on he's needs, if make sense.
Please follow these Links:
https://www.youtube.com/watch?v=_acFfT6v80U
https://www.youtube.com/watch?v=HWUbOxksu2M
Sincerely,
Daniel
