Without knowing what it is you're trying to achieve, it is impossible to give proper help. However, what you've already created should do the trick: just refer to your array parameter in your script.
Here is the purpose of having that array parameter - and I think I did It. I need the user to have the possibility to change the Glass Panels based on he's needs, if make sense.
Please follow these Links:
