CRASH !
I wanted some door settings from other file so I selected the wall that had the door I wanted from an ArchiCAD 10 file. Pasted it into the new ArchiCAD 11 (1033) file. Used Alt to get the settings and placed the door.
Went about my work for a while as usual no problems until I deleted the stuff I pasted into my new drawing. It crashes every time I do this.
Paste from old file into new drawing and then delete it.
Does this happen to anyone else ?
12 REPLIES 12
KeesW
I got a bit excited there!
Found out that, since the upgrade, our special libraries - including CadImage - were no longer where archicad thought they were. I've put them back and most things are now OK so far as library objects are concerned.
Cornelis (Kees) Wegman
cornelis wegman architects
AC 5 - 26 Dell XPS 8940 Win 10 16GB 1TB SSD 2TB HD RTX 3070 GPU
Laptop: AC 24 - 26 Win 10 16GB 1TB SSD RTX 3070 GPU
Yep, am having lots of the same problems here. I have updated AC11 in accordance with the most recent posts from GS and have the latest drivers for my graphics card and version of Quicktime and still the program is constantly crashing.
One thing i noticed...i was using ArchiStair ramps as SEO objects on curved walls containing a staircase and these ramps are automatically assigned to the Stairs layer. When I tried to change the layer name so that I could switch em off...AC11 crashed. So...I saved the file as an AC10 file...renamed the layers in AC10 and opened this file in AC11 and voila...problem solved....it seems a ridulously long winded workaround though.
Have also had to switch off the Update Autorebuild Model viewpoints continuously setting in order to avoid the slowdown in screen image regeneration.
All in all considering the amount of time wasted dealing with these issues I am not impressed with AC11 to date.
Having said all that if anyone has any constructive suggestions that might help I would be very grateful
crashing between 3d window and floor plan;
selecting a mesh or similar on the plan view, hit f4 to get 3d window of the mesh works fine, but if you mouse click on the plan view then archicad 11 hangs, and i have to force quit. some one in the office said you have to go back to plan by hitting f2 key. why is this, mouse click to activate floor plan window should work as well, just like it used to!
