Capitalization Routine?
Why doesn't this work? It's making me crazy. GDL is beating me up this week -- I hope it gets better next week.
This is in the Parameter script. Any other suggestions are certainly welcome!
!!ROUTINE FOR CAPITALIZING THE ROOM NAME
IF GLOB_MODPAR_NAME = `pCapitalize` THEN
NameLen = STRLEN(ROOM_NAME)
NewName = ""
SubChar = ""
FOR Idx = 1 TO NameLen - 1
NameChar = STRSUB(ROOM_NAME, Idx, 1)
GOSUB 1000
IF SubChar = "" THEN
NewName = NewName + NameChar
ELSE
NewName = NewName + SubChar
ENDIF
NEXT Idx
pCapitalize = 0
PARAMETERS ROOM_NAME = NewName
PARAMETERS pCapitalize = pCapitalize, ROOM_NAME = ROOM_NAME
ENDIF
GOTO 2000:
1000:
IF NameChar = "a" THEN SubChar = "A"
IF NameChar = "b" THEN SubChar = "B"
IF NameChar = "c" THEN SubChar = "C"
IF NameChar = "d" THEN SubChar = "D"
IF NameChar = "e" THEN SubChar = "E"
IF NameChar = "f" THEN SubChar = "F"
IF NameChar = "g" THEN SubChar = "G"
IF NameChar = "h" THEN SubChar = "H"
IF NameChar = "i" THEN SubChar = "I"
IF NameChar = "j" THEN SubChar = "J"
IF NameChar = "k" THEN SubChar = "K"
IF NameChar = "l" THEN SubChar = "L"
IF NameChar = "m" THEN SubChar = "M"
IF NameChar = "n" THEN SubChar = "N"
IF NameChar = "o" THEN SubChar = "O"
IF NameChar = "p" THEN SubChar = "P"
IF NameChar = "q" THEN SubChar = "Q"
IF NameChar = "r" THEN SubChar = "R"
IF NameChar = "s" THEN SubChar = "S"
IF NameChar = "t" THEN SubChar = "T"
IF NameChar = "u" THEN SubChar = "U"
IF NameChar = "v" THEN SubChar = "V"
IF NameChar = "w" THEN SubChar = "W"
IF NameChar = "x" THEN SubChar = "X"
IF NameChar = "y" THEN pSubChar = "Y"
IF NameChar = "z" THEN pSubChar = "Z"
RETURN
2000:
!!END
15 REPLIES 15
TomWaltz
How does it not work? What results do you get from it?
Tom Waltz
I start with ROOM_NAME being "Test Name", and after the routine runs, ROOM_NAME is still "Test Name" -- no change at all. It has clearly attempted something because the floor plan preview in the GDL editor blinks when I execute this routine.
	NewName = ""
	SubChar = ""
		GOSUB 1000
		ELSE
		ENDIF
	NEXT Idx
ENDIF
Jay,
One thing I see in a quick scan is that SubChar is set to "" outside of the loop, so after it ias assigned once in your 1000 Sub, it will never be "" again ... hence your IF will always be concatenating SubChar... so if you had "ab123c", your routine would produce "ABBBBC".
Rather than move the initialization into the loop, I don't see a need for that variable or the IF block ... just reassign NameChar in your 1000 Sub.
Tip for code on ac-talk ... there is a 'code' button in the format bar when you enter a message - keeps the indentation of the original.
AC 29 USA and earlier   ā€¢   hardware key   ā€¢   macOS Taho 26.1 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Oops. I originally had it set to "" at the beginning of the 1000 loop, but it still had the same result -- nothing.
Thanks! I never noticed that. A wish granted before I even posted it!
Having taken a clue from Karl, I change the routine to this:
	NewName = ""
		IF NameChar = "a" THEN NameChar = "A"
		IF NameChar = "b" THEN NameChar = "B"
		IF NameChar = "c" THEN NameChar = "C"
		IF NameChar = "x" THEN NameChar = "X"
		IF NameChar = "y" THEN NameChar = "Y"
		IF NameChar = "z" THEN NameChar = "Z"
	NEXT Idx
	pCapitalize = 0
ENDIF
This still doesn't work.
TomWaltz
Have you tried with without the GLOB_MODPAR_NAME to see if the routine works without the restriction?
OR, did you actually turn on pCapitalize in the Parameters window to trigger GLOB_MODPAR_NAME?
Tom Waltz
Right. pCapitalize is a Boolean parameter. Turning it on triggers the capitalization, at the end of the capitalization the programming switches pCapitalize back to 'off'.
Frank Beister
I think you have PARAMETERS once too much. Not:
pCapitalize = 0
but:
pCapitalize = 0
   ROOM_NAME = NewName
Haven't proofed, but this should do it.
Frank Beister
is a bit raw. šŸ˜‰
Try this:
low=ROOM_NAME
result=""
downT=" abcdefghijklmnopqrstufwxyz"
upT=" ABCDEFGHIJKLMNOPQRSTUVWXYZ"
FOR i=1 TO STRLEN(low)
  subT=STRSUB(low,i,1)
  posT=STRSTR(downT,subT)
  IF posT THEN
    result=result+STRSUB(upT,posT,1)
    ELSE
    result=result+subT
    ENDIF
  NEXT i
