Copying library part and renaming
Has anyone else had this problem.
All i did was change the name of a window in the library and remove some mullions using the script dialog in GDL.
When I save the new window name and reload it, one of the window openers is in the wrong direction and showing as a solid line.
Does anyone know how to fix this?
I have attached an image for clarity.
1 REPLY 1
Erika Epstein
Sounds like you did more than intended.
Are you DEL statements still referring to what the actions for which they were intended?
Did you save a copy of the original script? Try commenting out the areas you amended one at a time to see when and where the script starting giving unintended results.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
