You don't have to load the custom panel if you have just created it in that job.
Especially as you saved it in the 'Embedded Library' - it will automatically be there.
You only need to load if you save it to a folder and then you want to use that in another job.
However you do need to select the 'CW Custom Panel 18' option in the CW settings.
Then you will see a list of you custom panels that you can choose the one you want from.
Also the vent panel you have in plan - is that just lines or is it 3D elements.
If just lines then you will not see anything in the CW in elevation/3D.
It will still allow you to save it as a custom panel though for some reason.
The elements must be 3D.
