We value your input!
Curved Profiler Objects
Archicad 9... I've made a cornice moulding profile for the exterior of a building. All looked as it should in 3D and section. However, the next day, when I loaded the project, the curved areas have changed to a straight line. No curved lines show up. I've tried various object changes but cannot get the curved lines back.
The library part still looks correct with the curved line but will not show up ion the drawings. I've changed the setting in Magic Wand hoping that would help but no change.
Anyone know how to get the curves back in the profiler library object? Any help would be appreciated. Thanks.
11 REPLIES 11
TomWaltz
Do you mean the CADImage Profiler or the Archicad Profiler?
Tom Waltz
I believe it's the CADImage Profiler, as it is not the one that comes with Archicad, but an extra purchase.
Thanks,
Ron Vergilio
Ron,
You say "The library part still looks correct with the curved line but will not show up ion the drawings.". Do you mean in the preview or in the 3D
window of the GDL editing environment ?
Could you post the object ?
I do not have the CADImage Profiler but that should not make
a difference because I believe CADImage Profiler makes an
object made with the TUBE command.
Maybe we could see what the problem might be if we could
test the object.
Peter Devlin
Unfortunately, posting the object won't help because CADImage,
as I now remember, hides their scripts and it may be necessary
to have the add-on to even see the object.
Those that have the add-on might be able to help.
Peter Devlin
Appreciate the effort. Not sure how to post a copy of the object. Hope it comes through. Well it will not accept a .gsm attachment. How or where can I post the object?
TomWaltz
You have to ZIP if first.
Tom Waltz
Live and Learn. LOL...
Here it is.
Ron,
I downloaded the object "Trim 7.gsm" and
placed an instance in a new project.
The profile had only nine straight segments.
I checked the preview and it showed nine straight segments.
I opened the object in the GDL editing environment
and found that it appears to be an Archicad Profiler object
not a CADImage Profiler object.
The 3D view showed nine straight sides and the
Tube command in the 3D script had 10 polyline nodes.
As far as I can tell from the script, This object could
not have drawn a profile with apparent curves.
It would have had to have many more polyline nodes.
Peter Devlin
Peter,
Thanks for trying. Not sure what happened. The preview of the object shows the curved lines but now that's the only place that does. All else now just has straight line..
WI will try a different approach. Again, thanks for trying.
Ron
