Custom Door
Guillermo1
Witch is the best way to create an sliding door with 6 leafs?
Create ir as a new custom door or create only the leafs?
You have to create a custom door (including the frame) object.
Creating just the custom leaf (or 3 or 6 leafs as one leaf), will simply replace the door leaf used in a door frame.
The leaf will be resized to suit the frame,
You can resize the frame opening width of course, but it won't add extra sliding tracks.
5 REPLIES 5
Lingwisyer
Guru
There is a sliding door in the CI Essential Library that does up to 6. Was that a AUS/NZ thing? Does it still come with a Select (or what ever they renamed it to) Plan?
Ling.
where do i get this library?
Still there and under the same name in AC27.
AC8.1 - AC28 ARM AUS + CI Tools
24C GPU 7.8TF 32GB RAM OS Sequoia
Lenovo ThinkPad X12, i5-1130G7 @
1.1 GHz, 1.8 GHz, 16GB, Windows 11
CI is Central Innovations, look them up.
