Custom MVO pages
Bruce
Is there a way to utilise the Hierarchical pages function for custom MVO tabs?
I've got the code working, and it works in the Preview mode - but it doesn't actually work in the MVO tab. Is there a setting I'm missing?
I figure that I will need to do it the 'old' way, but thought I'd check first.
Bruce Walker
Barking Dog BIM YouTube
Mindmeister Mindmap
-- since v8.1 --
AC27 5060 INT Full | Windows 11 64 Pro | 12th Gen Intel i7-12700H 2.30 GHz | 64 Gb RAM | NVIDIA GeForce RTX 3060 32 Gb
JaseBee
I've had to do it the 'old' way, also had to do it like that for labels & zones. Kinda frustrating for my brain as it likes to have all the things work all the same... But Hierarchical is just so easy.
AC 24 5004 AUS
iMac OSX (10.13.6) 4.2ghz i7
8gb ram/8gb vram
Bruce
Yes - one day...
Bruce Walker
Mindmeister Mindmap
-- since v8.1 --
I just gave it a quick try and you are correct it works in the library global object preview but not in the MVO settings itself.
I assume it is something that will need to be programmed into the MVO settings dialogue to allow this to work.
I will try and get a request off for version 21 while I still have access to the testing forum.
I think it would be a good idea.
