Yes I have tried everything. Left, both, right. None of them do anything.
There also should be an option for showing the edge in 3d like all the other cabinets.
I see, I read you have the SOLO version, my object has the menu a little different as you can see in the image, does the solo version has localized versions or libraries like the USA library? I also see the name of the object is different. Did you try changing the setting in the Representation Tab?
